89 B2200 Ignition/Starting Issues
Old Dec 5, 2019 | 08:05 PM
taylor21293's Avatar
Originally Posted by Cusser
"Always fix FIRST what you KNOW is bad"
1. I'd test to see of you're getting any 12 volt positive TO the ignition switch, to help our understanding.
2. So someone before you had an issue there, get a replacement fuse for there first. Note that such large fuses are held in by a screw or two from underneath; disconnect negative battery cable first.
You're making progress.
Going to get a fuse tomorrow, but since I had the steering column cover off already, I decided to test the starter interlock switch.
If I’m following the schematic correctly, the interlock wire should be the B/Y stripe wire.
I then ran a test with the multimeter set to this setting:
Where I placed the leads:
Old Dec 5, 2019 | 08:16 PM
With ignition in the ”on” position, reading is around 11.6-11.7V. When the ignition is turned to the “START” position and held, the reading jumps to about 12-12.07V.
ErikSchempp
Jun 4, 2012 07:27 PM
scratcher09
Feb 28, 2012 09:34 PM
allout
Feb 17, 2012 10:33 PM
frannygirlnaz
May 7, 2009 10:44 PM
surrealistic
May 4, 2007 09:18 PM
