1987 b2600 interchangeable radiator
Old Apr 4, 2021 | 03:32 AM
aveedog's Avatar
Default 1987 b2600 interchangeable radiator
is there a make and model radiator, that will work in 1987 b2600?.thats not going to cost a arm and leg.thank you
Old Apr 6, 2021 | 04:12 PM
AutoMechanic's Avatar
Probably could find a good aftermarket one to fit or go to the junkyard and get one.
Old Apr 6, 2021 | 08:22 PM
90-B2200's Avatar
Many times radiators can be repaired. They remove the tanks, rod all the gunk out, fix leaks then braze it all back together. In the end it can be as good as new many times. This process works especially good on these older radiators with their brass / copper construction.
Look up radiator service and repair in your area and call for info.
Old Apr 7, 2021 | 08:16 AM
Cusser's Avatar
The B2600 engine (before the B2600i) with the Mitsubishi engine are pretty rare, so not so easy to find one, or a decent one, in a parts yard. Larger cities will likely still have a couple of radiator repair shops who essentially can rebuild the entire radiator.
Jan Kowalski
Jan 5, 2021 12:43 PM
Icepick
May 20, 2019 02:59 PM
biffula
Aug 8, 2017 06:42 AM
Sibroni
May 18, 2011 11:51 PM
Runerider
Jun 14, 2009 02:10 PM
