sputtering after driving for a few miles
Old Aug 29, 2012 | 04:21 PM
Robert Rehn's Avatar
Default sputtering after driving for a few miles
It started to happen not too long after I put in some USA gas. Since then there has been an oil change and some good mobile gas was put in on a nearly empty tank. It had a real basic tuneup done to it there is lucas injector cleaner in the tank as well but it is still doing it when it warms up enough. It idles about 1000 rpm with accelerating it normally goes to 3 to 4000 rpm but when it sputters it hits 7000. What could be the cause of it? This is a 95 Mazda 626 4 cylinder by the way.
Old Aug 29, 2012 | 04:23 PM
MazdaTirol's Avatar
If you think it may be bad gas change your fuel filter first, cheap and easy, plus if its old might as well do it anyways.
Old Aug 29, 2012 | 04:28 PM
I can't find the thing there must be something in the forum I am guess thats some sort of quasi manual for it. The tune up oil change and injector cleaner were needed in any event just for maintenance.
Old Aug 29, 2012 | 04:50 PM
tanprotege's Avatar
Do you have any digital trouble codes?
What exactly was done in the tune-up? Plugs, wires, rotor and cap, air filter, pcv, anything else?
Did they use the right plugs?
Is there a vacuum leak?
Old Aug 29, 2012 | 05:16 PM
Don't know how to get the codes. They cleaned the cap and checked the rotor they appeared ok and were cleaned a bit. I plan on replacing the plugs the air filter was clean. Last time I can remember they replaced the plugs with iridium ones a long while ago. Looking for some kind of manual on the internet to look at for the car to find things like the fuel filter.
Old Aug 30, 2012 | 09:06 AM
tanprotege's Avatar
Robert: log on to a parts store website and look for the parts.
Why Iridium plugs? Stick with OEM plugs or something of the same class. The engine was developed for optimum performance with these plugs. More expensive does not equal better.
What they did was not a tune up.
So your CEL light is on? Go to a parts store and ask them to scan it, they will do it for free. Jot down the codes.
Old Aug 30, 2012 | 03:22 PM
MazdaTirol's Avatar
Ditto, most engines run worse with the fancy plugs than with stock plugs. And if people say otherwise then maybe their engines are one of the very very very few that gain performance, otherwise their butt dyno needs to be re-calibrated :P
Old Aug 30, 2012 | 05:06 PM
I guess my Denso iridium plugs suck then. But then again, I am also running ACCEL 2V Ignition Coils that deliver almost twice the voltage as stock! No misfires here! The stock coils on the Mazda 6 are just good enough for the vehicle. (i know this isn't a Mazda 6 thread). I also had to put on another ground wire to engine block.
I thought this was relevant, somewhat!?
B-T-S
Mar 8, 2015 10:18 AM
john.smith
Jul 18, 2013 09:19 AM
Lev
Jul 17, 2008 07:19 PM
Tallisen
May 3, 2008 06:51 PM
electrondoc
Dec 27, 2007 11:37 AM
