SCREAMING 626
Old Sep 20, 2007 | 06:57 PM
petec@73's Avatar
Default SCREAMING 626
626-1991-2.2-16V SEDAN
I HAVE GOT A SCREAMING 626, WHEN STARTING FROM COLD ALWAYS SCREAMS, IF I TURN THE ENGINE OFF AND BACK ON A COUPLE OF TIMES IT WILL GO, AND SOMETIMES WHILE I AM DRIVING THE REVS DROP SHARPLY AND THE CAR STARTS SCREAMING WITHOUT ANY WARNING, ALSO AT TIMES IT WILL TRY AND CUT OUT AND THE CAR STARTS JYUMPING, ANY HELP WILL BE GREAT, WHEN I PICK UP MY YOUNGEST FROM SCHOOL AND IT HAPPENS SHE GETS VERY EMMBARRASED AND SHOUTS AT ME TO TURN IT OFF.
THANKS IN ADVANCE
Old Sep 21, 2007 | 08:34 PM
hixx's Avatar
Default RE: SCREAMING 626
Sounds like the altenator/p/s pump/a/c compressor bearing etc is trying to lock up. Or maybe just a loose belt. Anyway. Check the belt tension and condition. If you find no problem with the drive belts or related components that the belt is turning then it could be a timing belt tensioner bearing under the timing cover.
626v6
Apr 22, 2010 09:00 PM
bertengineer
Oct 14, 2009 09:01 PM
blan
May 13, 2008 12:15 PM
NewGuy181
May 14, 2006 03:44 PM
doormizzles
Apr 2, 2006 09:16 PM
