mazda transmission fluid help
Old Nov 29, 2008 | 07:43 PM
kingme's Avatar
Default mazda transmission fluid help
i own a 2000 manual mazda 626 and i cant find the fill hole for the gear oil and the manual version does not have a dipstick HELP
Old Nov 30, 2008 | 06:08 AM
Gimme3Doors's Avatar
Default RE: mazda transmission fluid help
Gear oil level is measured and added by removing the speedometer gear. There's a mark on the gear that indicates normal level of gear oil. Getting to the gear is difficult as it's in the back of the engine down low. Helps to have long skinny arms. You disconnect the speedometer cable and then there's one bolt to remove the gear and cover.
There's usually no reason to check the gear oil unless you've changed the CV joints. If you need to add hypoid oil, it's added where the speedometer gear is removed.
Old Dec 1, 2008 | 06:50 PM
krgbham's Avatar
You don't have to disconnect anything to check your MTX gear oil, just use a socket or wrench to remove the fill/check plug. If you're standing in front of your car, the transaxle/transmission is to the left of the driver's side wheel. You'll have to get under that side of the car to see it. You should notice a wire harness going to a sensor just above that sensor you'll see a large 17mm or 19mm plug. Remove that plug and put your finger in the hole if the fluid is right at the lower edge of the hole, you're good. If you can't feel it, you need to add fluid.
If you don't have a repair manual, the Autozone website has repair & maintenance info that you might find helpful.
Check this: http://www.autozone.com/shopping/rep...00c152800395ff
Old Dec 1, 2008 | 06:55 PM
krgbham's Avatar
by the way, Express Oil will check it AND add oil for under $10.00
excalibur03cc
Apr 11, 2015 07:10 PM
AKMorris
May 5, 2010 12:06 PM
OccamsShaver
Jan 15, 2010 04:27 PM
kman23
Jun 6, 2008 05:27 PM
mriley1045
Jun 6, 2005 11:38 AM
