Adding Manual Transmission Fluid??
I have a 1992 MX-3 and cannot find the plug for checking the manual tranny fluid level and adding fluid ..... I drianed the old fluid to change a half axel but the refill/level check plug is not where chilton's says it should be and the speedometer cabel connection is too low...... anybody got any ideas (or pictures)?
Thanks, Mike
Thanks, Mike
B6SOHC/F5M-R YOU USE THE SPEEDO GEAR.
K8DOHC/G5M-R YOU USE THE PLUG, PLUG RIGHT ABOVE THE REVERSE SWITCH ON THE FRONT SIDE. 23MM
OIL GRADE: API GL-4 OR GL-5:
VISCOCITY: ALL- SEASON SAE 75W-90: BELOW 0 F ATF DEXRON II: ABOVE 0 F SAE 80W-90
CAPACITY: US QTS 2.9
