mazda E5 engine cam timing set up?
Old Jul 4, 2025 | 04:42 AM
Riaan34's Avatar
Just trying to help.
I guess we have a technique difference in problem shooting. hahaha!
A leak down would have been after 2 types of compression testing first as one example .
Anyway good luck pulling the engine and tearing down the engine.
I tend to agree with Calisto on jumping straight to leak down test as there is symptoms you might overlook should you not do compression test.
Dynamic compression losses: Leak-down is static (engine not turning), so it doesn’t show what happens under real cranking conditions.
Valve float or timing issues: These show up only when the engine is moving, not at TDC with no motion.
Sticky rings or valves: Might seal well under pressure but not during cold starts or low-speed cranking.
Intermittent issues: A leak-down test is just a snapshot it won’t catch problems that happen occasionally.
Old Jul 25, 2025 | 02:45 AM
Oldmaz's Avatar
Default Engine Out
Ok, the engine is out and has been stripped completely, we’re talking naked! The cam is showing some pitting and two pistons are showing signs of damage on the skirts. Also all the ring lands are completely gummed up. It’s off to the machine shop for a line hone, deck the block and head, bore to 20thou, the crank is straight so is the head. I’ve gone for hyper-eutectic piston. Is anyone interested in me doing a vlog of putting Humpty Dumpty back together again😀
BIR
Mar 29, 2022 10:38 AM
bmatteson
Feb 22, 2022 03:53 PM
BillSchipper
Jul 16, 2019 03:12 AM
nsgary
Apr 12, 2014 01:17 PM
mazda99
Aug 13, 2008 04:18 AM
