ignition wiring colors?
Old Jun 1, 2009 | 06:53 PM
mazda323_87's Avatar
Default ignition wiring colors?
im converting my key to all toggle switch/push button on my 323.i have seven wires,i know only the starter,acc,on,and 12v constant,anyone help me with the others and how to wire it in.reason is i broke the damn thing,cars is gonna be used for short trips and dont wanna buy a new set.thanks guys.
Old Jun 2, 2009 | 11:34 AM
well im getting closer in what to wires together......just two wires at least if you guys can help me out.the two thinnest wires on the ignition cylinder backside.one red/white and an all black wire.i measured them carefully as i turned the key to acc,on,and start.no power ran thru them,are they grounds?can i not cut them and just leave them there?
Old Jun 2, 2009 | 12:28 PM
oldeng's Avatar
This won't help much, but is better than nothing.
Mazda wiring code convention is black= direct to ground: red/white= conditional to B+, meaning the red/white could be either a B+ input conditional upon some other switch/relay having the appropriate status, OR a B+ output coming from the ignition switch conditional upon the ignition key switch status.
Old Jun 2, 2009 | 12:36 PM
allright,so what woul be best as for the red/white wire?assuming more diagrams to look at this so far is the closest,thanks.
btalent
Dec 4, 2010 09:05 PM
ms3cbm
Apr 4, 2008 11:39 PM
nfpotter
Jan 16, 2007 12:38 AM
biancapaige77
Aug 27, 2006 04:36 AM
Motormouth
May 7, 2006 10:43 PM
