hold light flashing help please help me
I have mazda car 1994, sentia...
the hold light is flashing , and my car doest work, it give self , but its doest start.
I changed the delco + coil , but the problem still there
help me please
my life is nightmare, no body know what the problem is pleeeeeeze help
help me please
I have a 94 mazda 626 and the hold light was blinking and it wouldnt shift above second gear. the dealer was a lot of money to tell me the problem. i had my uncle look at it because i was told the cilynoid wire could be pinched what ever that is but he fixed it. hope that helps
check for spark and gas on the plugs. if there's no gas, maybe the injector connection plug is loose, or the fuel filter is plugged. get a manual from the library and read the tuneup section.
check ATF fluid level, replace ATF fluid and filter, check electrical connections and cross your fingers.
but most of all, micholson: don't answer posts that are 5 years old. ;-)
Had the same problem, blinking "hold" light. We disconnected the battery for 24 hours
and the problem went away. Hold light no longer blinks and the hold button works as
it is supposed to. Don't ask me??
mike
mike
trace66usa
Jul 3, 2008 04:08 PM
