HLA Question
Old Sep 21, 2013 | 11:23 AM
Cartwright's Avatar
Default HLA Question
Hi, new to this forum and seeking help.
Its a 96, 626 2.0 with FS engine. The head gasket was blown and I pulled everything apart to replace. Had a valve grind done while the head was off as well.
I had some compression before the tear down but after re-assembly there is no compression in any cylinder. It turns over as if the plugs were pulled. I believe the timing is set properly and have re-checked this many times.
I did take the HLA's apart and cleaned them. I read some information about priming HLA's during the re-assembly but I did not do this. Will a fully compressed HLA still open and close the valves properly?
Thanks
stpetejack
Aug 31, 2007 04:40 PM
lacawi
Aug 1, 2007 07:12 AM
