Engine cut off
Old Jul 24, 2006 | 08:01 PM
yong's Avatar
Default Engine cut off
Hi, I had a problem with my Mazda 323 FE (1991) a few days ago, while the car is running on the motorway, the engine will suddenly stop, rpm drop to zero. If I turn the ignition key to off and put it back to on (just before starting the engine) and release the clutch, the momentum will start the car but after a while, the engine will cutoff again. This happened a few time (which is very dangerous, especially while I am on the motorway). I am unable to start the car again in the next morning, the battery is charged, there is patrol, when I turn the key, I can hear the starter motor trying to start but it just doesn't starts. I tested the output (high voltage) of the ignition coil and there is no spark while there is 12V input. I am not sure whether the ignition coil is working and I am not sure is there anything else is broken. Any idea what could be wrong? Thanks and hope to hear from you soon.
Old Jul 24, 2006 | 10:48 PM
bkey71's Avatar
Default RE: Engine cut off
From what you describe, it sure sounds like an igniter problem The igniter is what conrols the coil and the tachometer. The igniter is also not a device that you can test with a meter being good or bad, as it is solid state.
I can tell by your english that you are not in the US, no problem though. Why I say that is because i only have specific info on US models.
Old Jul 25, 2006 | 07:46 PM
yong's Avatar
Car fixed, both the coil and distributor was broken.
joefrog
Dec 24, 2012 01:08 PM
myfaithchain
Aug 19, 2012 01:37 PM
dewdrinker66
May 11, 2012 07:34 PM
equinim
Apr 24, 2012 04:08 PM
guydot
Oct 2, 2007 05:15 PM
