Belt squeals even after replacement
Old Sep 22, 2010 | 09:56 PM
cpate's Avatar
Default Belt squeals even after replacement
I have a 2002 Mazda 626 4 Cylinder that I changed the belts on at the beginning of the year. The belts started squealing again so I had them tightened, but the squeal remains. Below is a list of symptoms the car is experiencing right now:
1. Belt squeals when the vehicle is turned on, sometimes even if the A/C is off when I start the car. Typically the noise stops after the A/C is turned off. I can turn the A/C on after the car has run a while without a squeal.
2. When the A/C is turned on while in drive, you can feel that it is putting a strain on the car.
3. I had a mechanic raise my idle rpm to 1000 to fix the squeal. That worked 2 days.
4. If the car is parked and in idle, the A/C compressor turns on and off every few seconds.
I think the fix would be to replace the A/C compressor; however I am not entirely sure that will fix the squeal. Anyone ever experience anything like this or have any suggestions. I hope I have been thorough enough.
FractuRe36
Feb 24, 2024 09:15 AM
zedsdead33
Oct 19, 2013 05:31 AM
chas
Sep 1, 2008 01:57 PM
achrukme
Aug 7, 2008 03:39 AM
anton1117
Nov 16, 2007 02:30 PM
