929 wont start
Old Nov 21, 2005 | 11:25 PM
bryanvan's Avatar
Default 929 wont start
my 92 929 has low compression like 75 lbs , it should still start right?
Old Nov 21, 2005 | 11:58 PM
bkey71's Avatar
Default RE: 929 wont start
Compression specs are 213 psi, with a minimum of 157 psi. Did you run a compression check on all 6 cyls? Did you do a wet compression check with a few ounces of oil in each cyl?
Old Nov 22, 2005 | 12:14 AM
bryanvan's Avatar
no i did not try that.
Old Nov 22, 2005 | 12:31 AM
bkey71's Avatar
You need to check all cyls first. It is possible the timing belt is broke or has jumped time if all cyls are low.
Old Nov 22, 2005 | 11:33 PM
babyhuey's Avatar
Unlikely engine is going to start it all 6 cylinders have that kind of compression.
Jul 24, 2014 09:39 AM
Godson
Feb 7, 2011 03:48 PM
homie2555
Apr 23, 2007 01:27 PM
XiL3D
Jan 21, 2007 12:16 PM
knightdown
May 24, 2006 03:29 PM
