626 Auto to Manual
Old Aug 16, 2016 | 11:04 PM
PinkOctopusRacing's Avatar
Question 626 Auto to Manual
We have a Mazda 626 that we race with but we want to swap out the automatic for a manual. We need any info as far as compatible cars for parts and/or information on parts cars with manual trans.
I believe the 626 & Ford Probe are mechanically similar.
Any help would be great.
The car is a 1999 626 ES with 2.0 liter I-4
Thanks
Old Aug 17, 2016 | 09:27 AM
shipo's Avatar
First thing we're going to need is the model year of your 626 as well as which engine.
Old Aug 17, 2016 | 10:29 AM
Oops, forgot the basics.
1999 Mazda 626 2.0 I-4
Thank you.
Old Sep 1, 2016 | 09:36 PM
I am surprised that nobody has any info.
Old Sep 2, 2016 | 12:12 AM
shipo's Avatar
I'm not; the conversion is a rather significant undertaking and it is virtually always better/faster/cheaper to sell the car with an automatic and buy a virtually identical car with a stick (assuming a manual transmission was a factory option).
Old Sep 2, 2016 | 09:42 PM
It may be easier if it were a normal car but since we have a roll cage and racing equipment installed it would be a big undertaking to get a new car.
Old Sep 2, 2016 | 09:53 PM
shipo's Avatar
Yup, I get that; the fact remains, beyond the work to replace the tranny and usually the half-shafts/axles, the chore of fitting the clutch pedal, clutch hydraulics, console modifications, the shift linkages, and the programming changes to the ECU (if necessary) can be quite onerous.
To be sure it can be done, especially if you have a donor car, but it is involved.
Old Sep 2, 2016 | 11:24 PM
A donor is what we are seeking. We understand the 626, MX-6 & Ford Probe share many components such as drive-train and was wondering if anyone can confirm or add to this info if possible.
Old Sep 3, 2016 | 03:37 AM
shipo's Avatar
I just did a little research and don't believe your 626 is compatible with either the MX-6 or the Probe, both of which ceased production in 1997 and were more or less compatible to the previous generation of the 626. That said, I've never really looked too closely at what changes were made between the last two generations of the 626.
Old Sep 3, 2016 | 09:08 AM
Thank you for the info, Every bit helps.
