1993 626 stops running
93 626 4cyl. Auto runs fine then for no reason will shut off. Takes a minute or two then will start up and run fine. Can go a mile or twenty miles before it will happen again. The motor can be cold or at normal running temp. We replaced the fuel filters. It has good fuel pressure. Replaced the distributor that went out about 3 years ago. Had the injectors cleaned professionally. We gave a visual inspection of the wiring harness and it appears fine. Seems to be electrical. When it shuts off the tach goes to 0 while coasting and the motor is still turning over.
ECU?? Distributor??
Your ideas are greatly appreciated.
Jeff
ECU?? Distributor??
Jeff
Camshapht
Jul 31, 2012 12:21 PM
CaptainBob
Oct 22, 2007 05:18 PM
