1989 323 High Cold Idle
Old Jan 18, 2015 | 11:59 AM
blitz128's Avatar
Default 1989 323 High Cold Idle
Hello All
I have checked out many sites for information on this and frankly have not found a good answer
I have a 1989 Mazda 323 non turbo. Engine revs very high at cold temps, at very cold temps it revs to the point that the the high rev limit kicks in, then revs again..... as it warms idle drops, but even when warm seems idle is still a little high.
Thanks
Keith
Old Jan 18, 2015 | 04:53 PM
hixx's Avatar
It probably has a slight vacuum leak. Use flammable brake parts cleaner to locate vacuum leaks. Spray it around the intake/injectors/etc. If the idle changes you found a leak. It sounds like the Idle Air Control Valve is working. I would remove the throttle body,remove the IAC valve and clean both. Replace both gaskets and clean the coolant ports out too.
dapgas
Aug 16, 2010 08:15 PM
drive4fun
Aug 7, 2009 08:49 AM
jeff1124
Dec 18, 2008 08:50 PM
shaffer20
Oct 6, 2008 09:15 PM
rbailey644
May 17, 2006 09:54 PM
