1988 Mazda 323 wont start
Old Dec 11, 2008 | 06:36 AM
bigwilly4u123's Avatar
Default 1988 Mazda 323 wont start
My Mazda 323 1988 no turbo will not start, when i turn the key nothign happpnes it dosnt click or turn over no soudn nothing, my lightss and my amp and stereo all turn on but my car will not start or anythign. Iv replaced the starter thinking that was it but i dont know what else it oculd be, my mechanic freind said it could be the key switch but i dont know. Anyhelp would be greatly appreciated.
Old Dec 11, 2008 | 11:01 AM
Gimme3Doors's Avatar
Default RE: 1988 Mazda 323 wont start
The first thing to check is the battery. Clean the terminal posts and clamps, make nice and tight. Now might be a good time to invest in a battery charger that can test for bad batteries. If the battery is 7+ years old, get a new one.
A quick test of the ignition switch can be made by looking for 12 volts DC at the positive side of the ignition coil with the switch in the on (IG) position. There's a wire with connector sticking out of the harness right at the coil to make such a test. You will need a meter,positive lead goes to wire, the negative goes to negative terminal of battery or use the engine. If you don't see 12VDC the main fuse could also have burned out, but doubtful.
ashleyjallen
May 24, 2010 06:23 AM
kkodra
Feb 28, 2010 03:37 PM
tntzfinezt28
Feb 8, 2010 05:03 PM
Fevered
Apr 13, 2008 10:37 PM
lubbie
Jan 14, 2008 09:17 PM
