"tune-up" for my 3 advice please
My baby just hit 50k miles today. 2012 mazda 3, 2.5L s. I put Simota short ram intake, but other than that, I have only changed oil and filter. What should it do for tune-up, and upkeep to get her to 200,000 miles?
Lucas fuel injector cleaner? If so, how often?
Any oil, or transmission additives? If so, brand, and how often? (automatic)
I am thinking its time to change the plugs. I have been told always go with NGK. Is there a big enough difference between the iridium and the laser iridium to offset the extra 6-7 dollars per plug? What plugs would you suggest?
I have the mazda app (a joke, i know) and it doesn't suggest much for the maint.
What milage should I do the coolant, and tranny?
Also, 0W-20 synthetic oil, should i change every 5000? 7000? 9000? I am in texas, gets pretty hot here...
Thank you for any advice in advance
Fuel Injector cleaner every year. READ: https://www.mazdaforum.com/forum/maz...y-34657/page3/ post # 25.
Tranny fluid change every 25,000 - 30,000 miles! Read: https://www.mazdaforum.com/forum/gen...cooling-35606/ Your in Texas, buy an External Tranny Cooler.
Spark Plugs soon. More expensive lasts longer. Stick with NGK. READ: http://www.ngksparkplugs.com/pdf/DYK...idium%20IX.pdf
Coolant I would change every 5 years, consider thermostat change.
Oil, depends how you drive. City driving, more frequent-less miles, highway less frequent with higher mileage.
1 item you forgot: change your PCV valve, cause Mazda never does.
Mazda App? WTF? What does it do? Show you closest dealer!!
Other items to think about: cabin air filter, brake fluid change, power steering fluid change.
How often for the pcv valve?
Thank you by the way!!
Marcus Caswell
Aug 16, 2013 12:08 AM
Tanzanite
Aug 13, 2013 12:19 PM
fruitbane
Feb 19, 2010 12:58 PM
