Tires balance and rotated problem
Old Sep 13, 2006 | 10:12 PM
esloyer's Avatar
Default Tires balance and rotated problem
Hey, got my car back from the dealer and while it was there I had the tires balanced and rotated. On the wya home I felt the car vibrate around 45 - 50 mph, is this normal? Is it just a tire that needs to be worn down or has the dealership done something wrong?
Old Sep 13, 2006 | 10:52 PM
babyhuey's Avatar
Default RE: Tires balance and rotated problem
If the vibration was not there before and now after a rotate and balance there is at a certain speed then one or more of the tires was probably not balance correctly. Have them try it again. Dingdongs.[:@]
Old Sep 13, 2006 | 11:10 PM
sstlaure's Avatar
Not necessarily. I've noticed that when I rotate my tires on my 3, specifically when I bring the rear tires to the front (I have directional tires on my car) that I get a noticable vibration. The tires wear on the inside edge (stock set-up has negative rear camber, so there is no way around it) and has caused the tread to feather a little (I've got 37,000 miles on my rear tires and they are Z-speed rated, so I think that mileage is fairly good considering.)
Just something else to check.
Old Sep 14, 2006 | 12:10 AM
esloyer's Avatar
they did move the rear tires to the front and i do have a 3...is it off balance or is this normal like sstlaure said. i have goodyear eagle one tires, not sure if they are directional
over45
Mar 28, 2014 04:38 PM
Randyr
Mar 21, 2010 04:17 PM
BogusSVO
Feb 1, 2010 06:28 PM
LordChrisofSith
Aug 1, 2007 10:10 AM
adam3250
May 15, 2007 07:55 PM
