protege will not start
My son's 02 Protege quit running on him as he was driving. He said the engine seemed to just start shaking and then the car just quit. It turns but does not start. We're getting codes of P0401 and P0340.
I removed valve cover and inspected the timing belt. The belt appears to be in good shape.
Any suggestions?
Any suggestions?
Sounds like your camshaft position sensor died on you. Check the plug and wiring leading to the cam position sensor. This sensor plugs in on the left side of the valve cover, toward the front of the valve cover, it's the only sensor there from what I have read so you shouldn't miss it. The P0401 could mean your EGR pipes/ports are plugged up too so a good cleaning of those may be in order as well.
Cataphract
May 3, 2008 04:33 PM
Cataphract
Apr 28, 2008 08:25 AM
