Miata dies or stalls when hot
Old Sep 6, 2007 | 10:28 AM
red_9782's Avatar
Default Miata dies or stalls when hot
Hi all, I am working on an 01 Miata, and when the engine compartment gets hot the thing dies, it tripped a code to replace the camshaft sensor, i did that and i am still having the same problem. It is not tripping a new code. If anyone has any ideas, i could sure use the help. Thanks
Old Sep 6, 2007 | 04:22 PM
hixx's Avatar
Default RE: Miata dies or stalls when hot
Not enough info really,recheck for codes/pending codes. You need to find out what it is losing,spark/fuel pressure.
Old May 15, 2008 | 07:52 AM
pkneen's Avatar
I'm having the same issue, if you find out what is causing your problem could u let me know please. I'll post again when i get some new info.
Old Jun 4, 2008 | 02:18 PM
pkneen's Avatar
After talking with some mechanics and replacing my camshaft position sensor. It seems like the problem is gone. So my advice is to replace the camshaft positions sensor which cost me $90.
Old Jun 10, 2008 | 08:38 AM
Mazmart Trini's Avatar
Check the ignition coils. Drifter28, newer cars do not have carbs.
rpgrayso
Jun 18, 2015 03:42 PM
GaryT
May 31, 2012 07:19 PM
CaitlinCarney
Oct 2, 2011 10:47 AM
exoticmiata
May 11, 2007 08:04 AM
peacereef
Apr 6, 2006 02:07 AM
