'92 Protege stalls only between warm and hot
Old Jul 29, 2008 | 04:50 PM
GaryT's Avatar
Default '92 Protege stalls only between warm and hot
my car recently started stalling between warm and hot, it seems once the car is hot it runs perfectly,
so far i've changed the plugs, wires, fuel filter, air filter and checked the cap and its fine.
HELP!!!
Old Aug 15, 2008 | 08:47 PM
GaryT's Avatar
Default RE: '92 Protege stalls only between warm and hot
Well it turns out that when the car doesnt start, there is no spark coming from the coil going to the distributor, but i dont know if its the ignition control module or the coil, or could i be somthing else?
Please advise!
Old Aug 16, 2008 | 09:19 PM
liz's Avatar
liz
does the car stall when stopped at intersectionor stop light/sign, but runs good when it is in gear and in motion? That was what was happening with my protege it turned out to be the coolant temp sensor, it was flooding out the car at stops due to a faulty sensor. we replaced the sensor and have had no ploblems since.
Old May 31, 2012 | 07:19 PM
s70simon's Avatar
I was going to say the same, check all ur sensors. Ect, maf, o2, iac, and others
airboz31
Oct 13, 2020 02:21 AM
xDread92x
Jun 30, 2014 05:07 PM
leftygolfguy
Nov 30, 2007 08:55 AM
cartroubles1
May 23, 2007 04:55 PM
