Miata dies or stalls when hot
Hi all, I am working on an 01 Miata, and when the engine compartment gets hot the thing dies, it tripped a code to replace the camshaft sensor, i did that and i am still having the same problem. It is not tripping a new code. If anyone has any ideas, i could sure use the help. Thanks
RE: Miata dies or stalls when hot
Not enough info really,recheck for codes/pending codes. You need to find out what it is losing,spark/fuel pressure.
I'm having the same issue, if you find out what is causing your problem could u let me know please. I'll post again when i get some new info.
After talking with some mechanics and replacing my camshaft position sensor. It seems like the problem is gone. So my advice is to replace the camshaft positions sensor which cost me $90.
Check the ignition coils. Drifter28, newer cars do not have carbs.
