Mazda Radio code reset
Old May 21, 2015 | 10:26 AM
  #251
Biggi's Avatar
Thank you BLUE_SP20, the code reset worked on a german spec Mazda6, built 2005. Saved me 65€ because I didn't have to take it to the dealer.
Old Jun 23, 2015 | 02:28 PM
  #252
mazja3791's Avatar
Hi, does anyone know the code that would work for a mazda 5 ts2, 2010 model. Ive tried the one reported by Blue above but no luck. Cant get to the stage where GOOD is displayed without it going back to err. Any help would be much appreciated. cheers
Old Aug 9, 2015 | 03:18 PM
  #253
Sergey211's Avatar
Default Mazda audio code reset
Hi,
My battery died and it locked my audio. I found your post and was excited to use it but got stock on step 2. I don't have numbers 8 or 9 on th dash. I only have 1 through 6. It's mazda 6, 2012.
Please help me out!
Sergey
Originally Posted by Blue_SP20
Hi people,
Im going to hopefuly help alot of people out, but at the same time will upset Mazda dealers.
I have the code to unlock Mazda radios the have 'ERR' due to 3 wrong codes. Do not listen to mazda book that states 3 wrong codes make CD playing Inop req replacement...
121 Metro DW10*2 > 203028, MX5 NB30P2, Milennia,323 BJ10*2, 626 GF10S2, Tribute.Step one:- press one at a time- preset 6, AM, Auto M, Seek ^ (up).Step Two:-Input this number, 4989.Step Three:- Press and hold Auto M and Preset 6 together.Step Four:- The Word 'GOOD' will appear on the screen indicated that the radio will work.Step Five:- Reprogram new Antitheft code into radio as per instrution manual.
Hope this helps some people out, save you some money as so.
Old Sep 12, 2015 | 09:22 AM
  #254
mazdamanic's Avatar
Sergey211,
You don't need numbers 8 and 9. According to my owner's manual, from a Mazda6 2004 but probably still applies, when you get to that stage you press 1 for the first digit, then press 1 four times.....then press 2 to indicate second digit, then press that 2 nine times, then press 3 for the third digit, then press 3 eight times, then press 4 once.....and then press 4 again nine times....if you get my drift ...let me know on here if it works !!
I want to disconnect my battery as I'm told that might get rid of the check engine light that's on all the time but I didn't want to do that as I don't have the radio code , so found this thread......I don't even know if a code has been entered on this car.....and I don't know how to find out.......wishing I hadn't bought a car with this issue but yes, you guessed it, I didn't know about this issue before buying it.
Old Oct 3, 2015 | 11:48 AM
  #255
borderbuddies's Avatar
I just bought a Mazda Premacy with the same problem.
The radio does not have a Auto M button though and do I need to disconnect the battery as it doesn't make a difference which buttons I am pushing it always shows the Errr message.
Old Oct 7, 2015 | 05:06 AM
  #256
I went to the local Mazda dealer to have it unlocked and he charged me £10.
I looked over his shoulder while he did it and if I remember correctly it was the following:
Press the following buttons
Audio
AM
ASTL
5FF
Then you will get the 4 digits to put in which are the same as with the other radios 4989
I hope it helps somebody
Old Oct 9, 2015 | 04:26 AM
  #257
frantic's Avatar
Smile frantic
Last night I reset my Mazda 626, year of regerstation 02. The code I used was 1414.
Thank you for the reset of the information
Old Nov 4, 2015 | 12:45 PM
  #258
koli9's Avatar
Thank you so much for this info. It really helped to solve my misery with my audio system. For me the code was 4989.
Once again THANK YOU SO MUCH.
Old Nov 21, 2015 | 06:04 PM
  #259
benny-z's Avatar
Default Mazda 5, 2008
Greetings from Sweden
I had Err on the display after 3 unsuccessful attempts to enter the code.
I tested Blue_SP20 solution, but it did not help, however I tested hold the volume button (the left button) and FM½ button simultaneously and the radio started and the error code disappeared.
Hope this can help others.
Mazda 5, 2008 radio
Thank you guys anyway.
//Benny
Old Dec 21, 2015 | 06:21 AM
  #260
stevew88's Avatar
Hi all
I have a Mazda 5 07 reg in the UK. What worked for me was holding down the large power button, then holding down FM1/2 for ten seconds. Everything sprang back into life!
Many thanks to all the previous posters, you've been really helpful!
Steve
