Mazda CX5 2017 rear wheel problems
Old Jun 28, 2024 | 12:32 AM
Feeleap58's Avatar
Default Mazda CX5 2017 rear wheel problems
Hello
After riding a few miles my rear left wheel makes a rubbing noise randomly then a loud metal sound like spring or something stuck in a gear box (just trying to describe what I hear ..) I took off the wheel, caliper..rotated the wheel bearing...EVERYTHING seem normal . However with re-installed and rotating the rotor it seems like sometimes its slowing down 1/4 of the rotation.....
with the wheel on its tough to.notice anything...
Could my wheel bearing going bad ?
if so would it be grinding all the time ?
Thank you for any help
Not sure I did a great job explaining;((((
Old Jun 28, 2024 | 09:43 AM
Well looking at your info location i have no idea where "vista" is in the world. There are hundreds of them? So, I can suggest what name of shop to recommend.
Also when you as a service question it is so important to state pertinent information .... Miles on odometer and when and what was the last service done ?
But basically, you need to find a service shop that can raise your Mazda on the lift and allow the normal weight bearing suspension. Then possibly the next check would be the "X" support lift that will allow the suspension to hang this will way the service mechanic/technician can start the engine place in a gear to see the operation and check for noises.
Old Jun 28, 2024 | 09:45 AM
Having done my homework I see that you live in Vista California. So I recommend(not in any order ) to go to Mazda dealership, Big-O Tires, or Goodyear for the inspection.
Old Jun 28, 2024 | 02:35 PM
Feeleap58's Avatar
Ok.thank.you
Sanc7
Oct 4, 2024 07:40 AM
Jennifer Lynn
Sep 28, 2017 08:02 PM
Frederick Buhr
Jul 27, 2016 06:16 AM
Nicholas Homcy
Jun 8, 2015 12:28 PM
pratibha
Sep 7, 2009 06:02 AM
