Lapping Valves in a Protege?
Old Nov 27, 2014 | 05:26 PM
147JK's Avatar
Default Lapping Valves in a Protege?
Guys I have the head off of my 1.5L (Z5) Protege due to a blown head gasket. While it's off, I was thinking about cleaning up the valves, including a light lapping. But this engine uses shims on the valve tappets and I do not want to have to buy new shims. Could a light lapping close up the valve clearances such that I would be looking at needing new shims, or does the lapping process not usually change the clearances that much?
Old Nov 27, 2014 | 07:23 PM
hixx's Avatar
It won't change it much but it could change it enough if it is at the edge of tolerance. I doubt it though. Just be sure to reuse the valves in the cylinders they came out of and replace the valve seals.
Old Nov 28, 2014 | 09:33 PM
147JK's Avatar
Yes, will do. Thanks.
johnuhl24
Feb 6, 2008 05:35 PM
Hulk78
Sep 26, 2007 10:12 AM
leserz
Jun 9, 2007 09:06 AM
yellowaz
Oct 23, 2006 10:38 PM
willowoak
Oct 1, 2006 08:46 PM
