Istop fault. Mazda 3 2.0 mar disi 2010
Old Mar 5, 2020 | 08:50 AM
Matthew Wood's Avatar
Default Istop fault. Mazda 3 2.0 mar disi 2010
So, I have a mazda 3 2.0 mzr disi 2010. Since I brought the car a month ago I've had the istop light flashing amber on my dashboard.
I did some research and found that it was a battery issue. Therefore, I changed the battery to a lion EFB 158 start/stop battery ( https://www.eurocarparts.com/p/lion-efb-158-car-battery-3-year-guarantee-444779341 ). With that still not solving the problem I took it to a garage which then reset the battery counter and coded in the battery (from what he said).
This got ride of the flashing light until I come to a stop, the system worked once then went back to flashing amber as before.
Has anyone else had similar issues?
for this system to work, am I going to have to change the other battery?
do you guys have any reccomendations on what battery to buy?
Thanks in advance
Old Mar 6, 2020 | 02:07 AM
That battery is the wrong one. You will need a Q85 battery ( EFB ) which has 650cca. your battery will be too small / weak for correct i-stop operation.
Old Mar 7, 2020 | 05:12 AM
Okay, What about my other battery? Does that need changing aswell to beable to do istop?
Also, could you attach a link with the right battery on please.
Thanks
Old Mar 7, 2020 | 05:27 AM
How many batteries does your car have?
All New Zealand new or Australian new BL Mazda 3's with i-stop have one x Q85 battery.
I've seen a Japanese used import BL with i-stop, that had two batteries, hence why I ask.
Old Mar 7, 2020 | 12:31 PM
[QUOTE=grim_reaper;181776]How many batteries does your car have?
It has 2 batteries
Old Mar 8, 2020 | 03:52 AM
In that case, you should contact Mazda and find out the required specs of your two batteries.
The two batteries are utilized for different purposes.
Was your car sold new in the UK? or is it a used import?
Tiger168
Aug 19, 2019 04:07 AM
lns1122
Jul 6, 2016 08:06 AM
tdunbar
Feb 18, 2014 11:18 AM
mattattack811
Jan 8, 2014 03:07 AM
FrankB5
Jan 1, 2014 12:33 AM
