Idle
Old 06-21-2007, 09:23 AM
MD's Avatar
MD
MD is offline
Default Idle
Hi guys
when a/c unit ON idle very bad -any clue
Thanks
George ,Baltimore
Old 06-21-2007, 03:56 PM
babyhuey's Avatar
Default RE: Idle
What year and model is your Mazda MD. If the idle up system is operating normally when you create a large electrical load such as headlights, heater fan, and rear defrost or when power steering is turned to full lock then sounds like the A/C compressor could be siezing up and dragging down the motor.
Old 06-21-2007, 08:33 PM
MD's Avatar
MD
MD is offline
Default RE: Idle
Hi, Thanks for respond
Mazda Protege 1998 DX 1.5 L 92 HP
Any load : Idle just fine - BUT if a/c ON- engine getting funny -about 300 RPM up and down ,- I thought EGR Valve
Regards,George
Old 06-21-2007, 08:47 PM
MD's Avatar
MD
MD is offline
Default RE: Idle
Hi
One more thing - Voltage regulator OK
Ice Cold Air/ Hot Air OK
Battery OK
a/c Unit Running just Fine -nice and quite
my thoughts - EGR or Amps/like short circuit/
Thanks
Old 06-22-2007, 06:54 PM
babyhuey's Avatar
Default RE: Idle
EGR could be sticking open and little at idle as you note. Also could have an idle air control valve getting weak and just not able to compensate for that large of a load.
Old 06-22-2007, 10:57 PM
MD's Avatar
MD
MD is offline
Default RE: Idle
Thanks
bobotech
12-03-2012 12:52 AM
j_r_42
08-06-2008 02:41 PM
REDKAISER
12-20-2007 02:52 PM
mcgiverdave
01-28-2007 03:26 AM
Quick Reply: Idle
