help with clutch
Old Sep 22, 2008 | 12:40 PM
misplaced miata's Avatar
Default help with clutch
ok well my 99 miata has been in the shop twice for the clutch and it is still acting up, first time it went in they replaced the master clutch, and the second time they replaced the whole clutch system but the problem is, that whenever i start up my car and push in the clutch it is real loose and will not go in gear i have to pump the clutch alot till it gets stiff then it will go in gear fine. and also when i am driving and have not switched gears in awhile it will do the same thing were i can not get out of gear so i pump the clutch get it out of gear then pump the clutch more to put it in the disired gear. i cant find what the problem is
Old Sep 26, 2008 | 03:49 PM
jkrigelman's Avatar
Default RE: help with clutch
If the act of pumping it helps the situation I would guess it may have a hydraulic clutch?
Have you checked your hydraulic fluid level or looked for any leaks in the hydraulic line?
OziSpeed6
Aug 4, 2013 11:27 AM
kayak-1
Jul 29, 2013 06:36 PM
mazdaprotege97
Dec 24, 2009 08:49 PM
S101031315
Dec 7, 2007 01:57 PM
Estlander
Sep 14, 2007 08:46 PM
