Engine Check Light
Old Dec 31, 2008 | 04:39 PM
curtfast's Avatar
Default Engine Check Light
Got a Miata 10thAnniv Ed, Standard with a check eng light on.
The error code is PO705 Range Sensor A, PRNDLR
Odd code to get (for an automatic) on a standard transmission.
Anyone have any ideas?
Old Dec 31, 2008 | 07:54 PM
MJP68's Avatar
Default RE: Engine Check Light
that same code for the manual trans is for the clutch switch (the small one located in the pedal assembly, not the starter interlock switch on the firewall)
p0705 neutral switch circut malfunction.
most likely the spring inside the switch failed. remove it and inspect continuity while pressing and releasing the plunger.
Old Jan 3, 2009 | 10:43 AM
curtfast's Avatar
Thank you! It is what I had suspected but the "auto trans" description threw me.
pdw001
Dec 5, 2022 02:54 PM
Rockstar
Mar 13, 2015 01:07 PM
KillerTofu
Sep 13, 2014 10:35 AM
brave-heart
Apr 21, 2010 07:44 AM
stoogefan32
Jul 10, 2009 07:50 PM
