Bravo B2500, Will not turn over
Old Mar 30, 2017 | 08:19 PM
Billsshed's Avatar
Default Bravo B2500, Will not turn over
Hello to all on the Forum,
First post as I have a problem with my work Ute.
I have a Bravo, 2006, turbo diesel ute. A very basic vehicle but I think I have an electrical fault. It is a reliable vehicle and has no history of starting issues.
History,
I have a tail light fault/short and it was this I was trying to trace, as it was blowing fuses when then park lights were turned on but the head lights work fine....then things went pear shaped.
Went to start the ute and waited for the glow plugs to go out and then turned the key......nothing. I can find no blown fuses or anything obvious. Battery is fine.
Questions, does it have a start relay? If so where is it located, how do I check the relay? fuses I should be double checking, fault finding technique? Could I have fried a computer when fiddling around with the light switches and loom? Anybody have a start circuit drawing?
Any help would be appreciated.
Bill
Old Mar 31, 2017 | 06:49 AM
Have you applied power direct to the starter solenoid.
Old Mar 31, 2017 | 05:37 PM
Billsshed's Avatar
Yes. No dramas there. Now trying to trace the power wire back to a relay or whatever. Will keep at it. I hope it is something silly and not a chip or the like.
Is there a relay? Where is it?
Bill
Old Apr 1, 2017 | 02:55 AM
Billsshed's Avatar
Found the issue. A loose connector which was hidden under the power steering resevior.
All good.
Bill
Hockey Ref
Apr 11, 2015 07:07 PM
Flebbert
May 28, 2012 07:48 PM
PeterSmith17
Oct 30, 2010 07:49 PM
br4vo89
Sep 12, 2009 07:11 AM
