2007 6 4cyl no heat at idle
Old Jan 7, 2013 | 04:28 PM
sonofsamspencer's Avatar
Default 2007 6 4cyl no heat at idle
Been a loong time on here.. That means things have been working well.
I have a from new 2007 mazda 6 4 cyl... Have had no work done other than regular maintenance.. It is freaken cold here today -10 Celcius.. anyway, on the way home we noticed the heat would disappear when the car is at idle.. not over heating on the guage... eveything looks fine.. fan running fan.. soon as I take off or revv the engine the heat comes back instantly.. Wierdest thing.. I can't figure it out.
Anyway, I am going to check it for low fluid when it cools down - but wouldn't the engine have gotten overheated if that was the issue? or the waterpump? Why does a higher idle make the heat come back..
Anyone?
T
Old Jan 7, 2013 | 11:04 PM
tanprotege's Avatar
The waterpump speed is depending on the engine RPM.
You do the right thing checking on the fluid. I had a similar situation with wifie's Ford Contour and the coolant level was low, no overheating. I added coolant and everything was fine, noticed coolant going down again and added Bar's leak stop. While the coolant was low the heater worked inconsistantly.
If the coolant level is fine I would suspect a partially clogged heater core or a water pump on the way out.
Make sure the drive belt is a -o.k.
Old Jan 8, 2013 | 04:47 AM
racer662009's Avatar
Sounds like u have some air in the system usually caused by being low or changing the coolant and not burping it.
Old Jan 8, 2013 | 03:32 PM
Yeah, I have never touched the system from new. I did add about less than a quart of coolant last night and my wife took it to work today and she said it seemed better. However our cold snap has come to an end... It seems like the water pump might be on the way out. are they tough to replace?
T
reviewer8
Jul 6, 2022 09:46 AM
nsgary
Apr 12, 2014 01:17 PM
the_gray_mazda6
Feb 4, 2009 06:15 PM
MHfry1
Jun 14, 2007 06:03 PM
zl2k
May 28, 2006 04:45 PM
