2005 Mazda 6 issue
Old Dec 28, 2008 | 06:16 PM
aoconnor2123's Avatar
Default 2005 Mazda 6 issue
I have a question about my car. I have looked on this website at a lot of the vibrating questions and answers but can't find my problem. I'm new to this and need help!! My car is no longer under warranty. It's a 2005 Mazda 6 2.3 Liter. The problem is it makes a vibrating noise. it seems to be coming from the front somewhere. It only happens when I am stopped at a light. When I put it in nuetrul it stops. The noise happens when it's in reverse, or in gear but only when i am stopped. Can someone please help me??
thanks
Old Dec 28, 2008 | 11:09 PM
VB's Avatar
VB
Default RE: 2005 Mazda 6 issue
Can you go into detail? ATX or 5 speed?
If your car's only doing this in gear while stopped, take a look at your tach...are your RPMs dropping to lower than normal levels? Does it feel like the car's making a bit of a choking motion?
Old Dec 29, 2008 | 03:09 PM
JS's Avatar
JS
Hi
Mazda Protege DX/auto/=
Gear on P Idle just Fine
Gear on R Idle just Fine
Idle on D or D1 and Idle about 200-300 RPM down
Did not find any answer yet
I did higher Idle-so from now Car onParking has higher Idle on D about Normal
RegardsJS
Old Dec 30, 2008 | 06:31 PM
My car is a ATX automatic. It seems to stay around 1000 rpms while stopped. I don't think its chocking but the way i can descripe it is it feels like it's about to die like it vibrated like when it's going to die because the battery went out but it also makes a noise like somehing is loose or cligging. I just bougth a new battery not to long ago
Old Jan 15, 2009 | 12:07 PM
JS's Avatar
JS
I believe it isabout air valves located on the top of engine and firewall
MAP or EGR boost sensor canmake that crap
Old Mar 20, 2011 | 01:32 AM
hawkertroy's Avatar
Default Engine problem
2005 Mazda 6i... All you guy's with the California ultra low emmisioned 2.3 ltr 16 valve engine in the 2005 and 2006 vintage, learn how to pray now!!! the crank gear is held on by a one time use bolt and a slight taper in the crank, when this gear is stressed in just the right way, it WILL spin on the shaft independant of the shaft!!! These engines are a interference engine, so my friends, this means your engine is toast. All those valves seem to run into things, like pistons, when this happens and your wonderful low emmision engine is at absolute zero for compression... Then you think, I will just get it rebuilt, wrong again, nobody wants to rebuild them because they can't get the engine specific parts.
Old Dec 27, 2012 | 05:29 PM
MazdaGirl77's Avatar
This is an old conversation, but I'm having similar problems as Connor. However, I'd describe my problem as a spuddering feeling while stopped. 'Doesn't matter if I'm in P or stepping on the breaks. I also get the same thing while in N. The pcv and spark plugs have been changed, oil changed, filter good...
Old Dec 27, 2012 | 05:56 PM
Mileage?
Change all your ignition coils.
Clean your MAF sensor.
Clean your EGR valve.
Clean throttle body-----click here: Rough Idling Issues |*MotorWeek
Those are the basics
Old Jan 9, 2013 | 03:34 AM
Check your engine mounts. Especially the main one above the drive belts. It needs to be removed from the car to check it properly.
TheCrashmaster
Aug 26, 2018 10:50 PM
pwr shft
Apr 5, 2011 11:01 PM
JRFROMDR
Nov 18, 2010 02:10 PM
mrgrims
Aug 5, 2009 02:52 AM
stpetejack
Mar 16, 2009 07:47 PM
