How tight is the 2.0L motor? Trouble turning at the crank
Old 08-09-2010, 08:39 AM
actionpaintball's Avatar
Default How tight is the 2.0L motor? Trouble turning at the crank
Replacing a 2009 Mazda3 2.0L motor from a theft recovery. I have a low mileage used engine with 6 month warranty on the engine stand ready to go in. The engine seems extremely tight....can turn over on the flywheel teeth, but it will not easily turn over on the crankshaft pulley via the crank bolt. Should this be a concern or are these engines normally really tight?
There is no mechanical resistance turning on the flywheel, and I will pop off the valve cover and verify cam timing and crank top dead center. Engine has plenty of oil and looks basically brand new.
Old 08-09-2010, 12:40 PM
Tracker's Avatar
Shouldnt use the pulley bolt to turn crank, its not a keyed pulley, ur actually running a risk over tourqing the bolt, use the special tool that is used to hold the pulley in place to spin the pulley
1parkpointer
08-26-2010 04:34 PM
Cataphract
08-26-2008 08:10 PM
dbillinois
01-11-2008 12:08 PM
jaben
12-09-2007 10:31 AM
tdc100
05-17-2006 06:22 AM
Quick Reply: How tight is the 2.0L motor? Trouble turning at the crank
