Vibration at 60mph only when gas is hit
Old 02-05-2017, 01:05 PM
bcoolman's Avatar
Default Vibration at 60mph only when gas is hit
So I have a 2005 Tribute v6. It has a hard vibration like the tires are out of balance but only when I hit the gas at above 60. Smooth as glass when I let off of gas. So its not the tires. Even at 80 its smooth unless I hit the gas.
Any ideas what could cause this shaking?
Old 02-05-2017, 01:27 PM
simonsi's Avatar
Check all the driveline couplings, likely one has some movement under drive which moves it out of balance but it relaxes under over-run back into its correct balanced position.
If they are all good Id suspect one or more soft engine mounts.
Old 08-17-2017, 05:02 PM
waynar70's Avatar
had same problem. had Mazda do a check and they said my right front axle was loose. 2003 v6 ES
Revo13
04-05-2017 08:05 PM
sashko1
04-01-2011 06:18 PM
mzdaspd304
04-11-2009 05:07 PM
pegman456
10-17-2005 07:20 PM
Quick Reply: Vibration at 60mph only when gas is hit
