Squeak in steering when turning
Old 01-13-2007, 02:55 PM
billhendley's Avatar
Default Squeak in steering when turning
When ever I turn the steering wheel there is a loud squeak coming from the left front wheel. I removed the wheel to investigate, the squeak seems to be originating from the steering box. Is there anyway to lubricate that area?
Old 01-16-2007, 08:11 PM
babyhuey's Avatar
Default RE: Squeak in steering when turning
Two known sources of squeaks from the steering system. First one is easy fix. Look down to where the steering column shaft goes thru the floorboard and there will be a rubber boot around it. Lubricate the contact point between the stationary boot and steering shaft and see if noise goes away. If not, the other common source is due to the fluid. Mazda recommends flushing out the old fluid and refilling with Mercon V auto trans oiil.
krisbee
10-28-2014 01:16 AM
moozmooz
02-03-2013 06:02 PM
DavesGTO
05-09-2012 12:06 PM
TomK
10-10-2010 07:42 PM
Lev
05-08-2006 06:07 PM
Quick Reply: Squeak in steering when turning
