2001 Tribute, Timing Belt/Chain
I just bought a used Tribute and have been getting conflicting information on whether it has a timing chain or timing belt! It has 102,000 miles on it so it's kind of important to find out which one! Any factual information would be greatly appreciated!
RE: 2001 Tribute, Timing Belt/Chain
On the V6 engine you can see the timing chain thru oil filler opening. Tribute with V6 engine has always used a timing chain from 01-06. The 2.3l 4 cylinder used in the Tribute in 05 and 06 is also chain driven.
The 2.0l 4 cylinder engine in the 01-04 Tribute is the only one that has a timing belt.
ahhhh, ok, so lesson learned for me...to post what kind of vehicle. It's a 2001 mazda tribute dx, 2.3L 4 cylinder. I guess that's why I keep getting different answers! Even the dealership told me today it was a CHAIN. But if babybuey is correct it's a BELT. That may be the least of my worries anyhow, tonight I lost all power to it on my way to work! So if anyone can help with this I am changing the subject a little, I know, but.....I have a manual transmission, and today when I would take it out of gear into neutral it would rev up to about 3.2 on the RPM gauge.After I would come to a complete stop it would go backdown to 1.0 like normal, it was only if the car was moving that it reved up (and I was not touchingeither the gas or clutch pedal.Then tonight I lost all power. And I do mean ALL. Thanks all you guys for your help! Feeling like my first car buying experience without a husband has gone very very very badly!
Timing belt/chain
I own a 2001 Mazda tribute V6 with 202,000klm's and have NEVER changed the timing belt/chain. Am I pushing my luck?
If they aren't noisy then all is normally well, if they go noisy then it should be investigated to see if a tensioner has failed.
The spec on life of the chains is, I believe, the life of the engine...
michalisma
04-21-2012 07:04 AM
