RX-7 Warning Light problem
Old 10-12-2007, 09:40 AM
jamieshannon's Avatar
Default RX-7 Warning Light problem
I have 1991 RX-7 convertible, 76,000 miles,nice condition. It's my second car, so I only drive it about once a week. As I was driving to work this morning, the seat belt warninglight unexpectedly came on, followed by just about all of the other warning lights - battery, fuel, oil, washer fluid, etc. The car seemed to be running fine, but I immediately returned home. Is this an electrical problem or something else? I've had problems in the past with the battery draining, apparently because I don't drive it often enough. Is this problem related to that?
Old 10-12-2007, 06:35 PM
hixx's Avatar
Default RE: RX-7 Warning Light problem
Could be alot of things. All that stuff runs through the CPU which is in the interior fuse block. You basicly have some tracing to do. Fuses/grounds/altenator/etc.
Old 10-12-2007, 07:00 PM
you may want to have the alternator and the battery checked to make sure the alternator is charging and the battery is holding the charge
Old 10-24-2007, 09:41 AM
Mazmart Trini's Avatar
ORIGINAL: trailermech78
Agreed. Sounds like the alternator is giving up.
Old 10-29-2007, 03:16 PM
Check to see if you have a broken alternator belt also.
B-T-S
04-27-2015 01:30 PM
brave-heart
04-21-2010 07:44 AM
tomm
10-03-2007 12:46 PM
Jul
05-08-2007 06:52 PM
barefoot_gal
01-13-2006 11:36 PM
Quick Reply: RX-7 Warning Light problem
