goofed again
Old 09-22-2015, 11:55 AM
trickrider's Avatar
Unhappy goofed again
Today I replaced a burnt out bulb in my instrument cluster .While I had it out I took the face off to clean the cluster face when I did I bumped my temp guage needle and now it does work correctly . Can I fix this screw up ???
Old 09-28-2015, 07:20 PM
trickrider's Avatar
Lightbulb Easy fix if its apart
If you take the face of the gauge cluster off you can reset your gauge by turning your key off , with your finger set the gauge as close 0 or the begining of the gauges cycle, mine was c or cold for the temp gauge.The fuel and the alternator gauge came back on there own I didn't play with the gauge needles . With all that said you zero out the needle and turn the key on and see if its near 0 or normal . If not turn the key off and try again it may take a few tries , just remember to turn the key off between each try . This works ! Actually the hardest part is taking the dash apart at least the most time consuming . This worked on my 2002 mazda b3000 ds . Not sure if its the same on all these trucks but It worked on mine ! Hopefully this helps some one, If I'm wrong some please correct me .
ripcbx
04-07-2006 08:16 PM
texasgal626
04-01-2006 05:11 PM
the_gray_mazda6
09-07-2005 06:02 PM
superloudrx7
08-18-2005 09:41 AM
MazdaN20
07-22-2005 07:19 PM
Quick Reply: goofed again
