Crank shaft spacer
Old 04-03-2008, 11:39 AM
stcr1's Avatar
Default Crank shaft spacer
I recently bought a 91 b2200 fuel injected. I noticed a funny knock at the front of engine. I discovered that I can move the lower pulley (at crankshaft) in and out about 1/2 inch. Any ideas what may cause this? Is there a spacer at the front of the crankshaft on this vehicle? Let me know if anyone is farmiliar with this problem. Thanx
Old 04-03-2008, 11:58 PM
mazdab2600's Avatar
Default RE: Crank shaft spacer
some crank bolts have a big thick washer others have it as part of the bolt.
check yours and make sure the bolts tight.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
dogg123452
11-08-2010 06:03 PM
jd3612
04-11-2008 05:14 PM
jd3612
06-13-2007 03:26 PM
Kage2021
03-15-2006 06:59 PM
Quick Reply: Crank shaft spacer
