a/c quit
Old 08-31-2007, 09:04 PM
Jerry's Avatar
Default a/c quit
OK, I'm new here, but I tried to search the forum before posting. So if I've missed something obvious, I'll try to do better. I have a 91 B2200 which up to yesterday had VERY cold a/c. Yesterday I stopped to jump off a lady who needed help. Everything was fine for the jumpoff, no sparks, no problems. The idle speed didn't even drop when she started her car. When I got back in I realized the a/c had quit. Now I have a dead short across the a/c fuse--blows the second I put it in. It also blows the fuse no matter whether the a/c button is in or out, and even with the switch turned off and the key out of the truck! I thought that was a switched circuit--can somebody tell me what's going on? I bought this truck in May and it didn't come with an owner's manual, so I don't have a schematic. Any help, ideas, or wild stabs in the dark are appreciated. I'm in Alabama and the humidity here is everything you ever heard it was, and then some. And no, you don't get used toit just because you grew up here. Thanks!
Old 09-01-2007, 08:22 AM
hixx's Avatar
Default RE: a/c quit
Very odd that it blows with the key off so i would start by pulling the steering column cover and check the back of the ignition switch for melted solder contacts. Disconnect the compressor from the circuit and see if it blows the fuse. By disconnecting components one at a time you should be able to find it by process of elimination.
cugene
04-28-2007 02:19 AM
crazylegs
12-28-2006 02:43 AM
nixon186
10-24-2006 12:43 PM
jdh
09-25-2006 05:35 PM
Mazdaboy2600i
02-14-2006 01:02 AM
Quick Reply: a/c quit
