1987 B2200 Valve Stem Seal Replacement
Old 11-23-2007, 09:36 AM
Josdek's Avatar
Default 1987 B2200 Valve Stem Seal Replacement
I ran into a snag do this job...I have a decent valve spring compressor but when I compress the spring, the valve moves with it, it doesn't stick up to expose the keepers. I am using about 80lbs of compressed air to hold the valve in place but it seems almost stuck, when I've done this before there was no problem with the valve staying up. Is there a trick to this? Thanks for any input, I need the truck back!
Old 11-23-2007, 11:07 PM
Josdek's Avatar
Default Ok Problem Solved
Seems like the keepers (locks) were stuck. After compressing the spring I tapped on the compressor with a hammer and they came loose.
Fat Cat
04-10-2020 04:06 PM
duckofalltrades
11-21-2013 07:18 AM
DavidJP
11-15-2011 12:14 AM
mazdabakki
10-01-2007 03:26 PM
nastynate
03-21-2007 09:31 PM
Quick Reply: 1987 B2200 Valve Stem Seal Replacement
