Headlights
Old Nov 22, 2007 | 01:21 PM
ahioctane's Avatar
Default Headlights
I have got a 1989 mazda b2600i 4x4 and all of my lights come on except my headlights. Anyone have any trouble shootingideas?
Old Nov 22, 2007 | 10:25 PM
Cusser's Avatar
Default RE: Headlights
I'll assume that you've already checked the headlights themselves; these are dual-filament low/high sealed beams. Your running lights and your headlights are on different circuits; each has its own 30 Amp fuse. First check the headlight fuse: it's the rearmost of the three fuses, under a cover just rearward of the battery negative terminal (you can do all this with the ignition key off).Be aware that ifthis has blown, something has made it blow; anyway, if it's bad, I'd replace that and see if it works.If that blows, then you have a short. If the fuse is OK, use your circuit tester light ($5) or voltmeter (digital multimeter on sale at Sears for $10 Friday morning, I have two) and make sure that voltage is leaving that fuse. If OK, then remove covers just forward of the steering wheel, and check voltage of the RED wire. If OK,rotate headlight switch on and check voltage in RB wire for low beams (red with black stripe) when selected and RW wire forhigh beams (red with white stripe) when switch pushed all the way forward. If you get voltage there, then you've isolated it to wires, connectors, sockets, or bulbs for the headlights. The RW wire also tees off to the blue light in the dash above the temperature gauge.
Old Nov 26, 2007 | 07:38 AM
toddluck's Avatar
do you have hi beams if you pull back on the lever??
daepeltz24
Apr 4, 2007 04:47 PM
curbs02
Jun 3, 2005 02:35 AM
Patsplace
Dec 18, 2004 04:58 AM
jayman
Nov 21, 2004 02:51 AM
daepeltz24
Apr 26, 2004 03:12 PM
