Car sitting for 6 months. Maintenance?
Old 03-22-2008, 03:06 PM
nOrcAL7's Avatar
Default Car sitting for 6 months. Maintenance?
So the car was sitting for 6 months. My brother states the battery died because of the alarm drained it. So I put a new battery and she started up fine, however, I did notice that when she sits for a couple days, and I start her up again. One of the belts squeal. My question is.. should I changethe belt or is the belt loose? I also took a look at the oil & the coolant. They appear to be fine, however would you still change the fluids?. Thanks in advance.
Old 03-29-2008, 01:49 PM
nOrcAL7's Avatar
Default RE: Car sitting for 6 months. Maintenance?
Wow over 30+ hits and not even a reply. Come on now, someone has to have an answer.
Old 04-01-2008, 02:29 PM
you should always be changing your fluids... even if you don't run your vehicle for long amounts of time. Oil is a must unless you want to destroy your engine. I change my oil in my dakota that I keep in my garage twice per year. I use a full-synthetic as it has a cleaning agent involved for Pennzoil Platinum.
I would suggest you use a trickle-charger for your battery when you are storing it.
Old 10-13-2008, 11:26 PM
hey bud i would definitely change/top up fluids, possibly change spark plugs or distributor, and take a good look at your tires and rims if its sat for 6 months in one spot never being moved.
Deisel Rob
05-25-2015 09:46 AM
kl884347
01-25-2010 09:13 AM
ActionClaw
11-06-2007 12:08 PM
rockbydefinition
08-12-2007 08:54 PM
Quick Reply: Car sitting for 6 months. Maintenance?
