Losing Coolant Fluid
Old 10-11-2008, 07:45 PM
oldzoomer's Avatar
Default Losing Coolant Fluid
I have a 2002 MPV which just turned 100K.
We love it, although we have had a few problems.
Last winter it would not get warm. I suspected the thermostat, and the garage fixed it. They told me that I was correct, that it was the thermostat.
This summer, it got hot, so I checked the coolant level. It was low, so I filled it. Problem resolved. Happened again, same fix. Now I'm wondering if that was my problem last winter.
But, the big question is: where is the coolant going?
I saw an old post that said the reservoir was split.
Any other possibilities? Engine seems to run fine, no coolant in oil.
Thanks for any ideas.
Old 10-13-2008, 04:17 AM
Default RE: Losing Coolant Fluid
hi mate if you have rear heater controls just check the floor behind the rear wheel for any coolant leaking there.
my friends MPV which is 2003 model is just had this problem this is the link it'll save me explaining on here.
https://www.mazdaforum.com/m_81202/tm.htm
it might be something you've not checked, i'll be honest i was suprised coolant was leaking from the rear wheel arch
Old 10-13-2008, 04:32 AM
oldzoomer's Avatar
Thank you, Eddieace.
I will check that out ASAP.
Old 04-14-2011, 04:16 AM
rampg's Avatar
Default How did you fix the trouble?
Rear wheel may be water from rear a/c unit/
I seem to be loosing coolant through a piston or two. I get abnormal engine vibration and my coolant reservoir caps seems to want to blow out. Can this be diagnose with the onboard computer?
Jmarcin
07-09-2014 07:09 AM
Stevoh
06-21-2010 03:17 AM
Alex4
01-07-2009 07:54 AM
mazda guy
11-12-2005 03:33 AM
Quick Reply: Losing Coolant Fluid
