Error codes, P0108, P0171,P0174
Old 04-26-2008, 09:09 AM
cincy_mpv's Avatar
Default Error codes, P0108, P0171,P0174
Hello,
2000 MPV
The P0108 says "Map/Bar0 circuit high input", the others I found on this site indicate bank1 & 2 are too lean. I was thinking the intake manifold gasket is leaking? My VIN isin this range. I would like to check the torque on the manifold. Can someone please provide the torque spec for the intake manifold?
I dont know if this is it or not but its free to check. I also put some cleaner/fixer stuff in the gas tank incase the gas is bad or water in tank.
Not sure about sensors? if someone knows what P0108 means in laymens terms? Is this the map sensor dirty/bad? If so where do I find it...
Many thanks
Old 04-26-2008, 11:17 AM
cincy_mpv's Avatar
Default RE: Error codes, P0108, P0171,P0174
Follow up...the P0171 and P0174 codes are gone..P0108 wont go away. I would still like to know the torque for the intake manafold screws. The detail report on the diag tool says Fuel Sys 1 OL Fault. Which seems to make sense since Map/bar0 Circuit High Input is the text for this error. Any ideas?
Old 05-04-2008, 07:26 AM
My 2001 mpv has a P0108 and my mechanic tells me it is a faulty MAP sensor. Was that what yours turned out to be? I am curious.
Thanks.
Old 05-10-2008, 07:52 PM
cincy_mpv's Avatar
Well I havent fixed mine yet. I think it may be the hose? The sensor was $225. Not going to shot gun it at that price. I was out of town. It runs fine just has the light on. I have cleared it but it comes back on. I had some fluid on the connector, not sure why so I may just clean it all up, reset the light and see what happens. This sensor doesnt typically go bad according to the parts ppl.
azkev
03-11-2012 10:00 PM
themcmullens
03-10-2012 08:20 PM
cassincali
11-03-2010 09:46 PM
mmiller2002
04-26-2010 02:51 PM
linebers
01-27-2007 01:09 AM
Quick Reply: Error codes, P0108, P0171,P0174
