2003 MPV Running rough OBD2 Error Codes
Ok I have 2003 MPV and it is running rough. The engine light came on but has been running ok until a couple days ago. The Mileage went in the dumper a quite awhile ago. I bought a Code reader but I need a bit of help cifering out what exactly they all mean.
I figure the P0421 is that the Catalytic converter may be bad.
the part I am not sure if is which O2 Sensors are which What does Bank 1 Sensor 1 mean? Is this the sensor front Radiator side in front of CaT or Back Side front of CAT.
Also is Bank 2 Behind CAT?
I want to make sure I get the correct parts I need to fix the problem.
MIL DTC
P0421
Warm-up Catalyst Efficiency Below Normal (Bank 1)
Pending Codes
P0131
HO2S-11 (Bank 1 Sensor 1) Circuit Low Input (No Inversion)
P0151
HO2S-21 (Bank 2 Sensor 1) Circuit Malfunction
P0300
Multiple Misfire Detected
Now I have one other Question.
If I have to order a CATALYTIC Converter is there only one on the 03 MPV and if so is the 3 bolt Inlet 2 bolt outlet bolt in model the correct one for my application?
Thanks 1000 times over in advance for any help.
Todd Fiebranz
Damin69
MIL DTC
P0421
Pending Codes
P0131
P0151
P0300
Todd Fiebranz
Damin69
Patrick Chin
02-07-2024 08:08 AM
Patrick Chin
08-16-2021 11:30 PM
