Trunk / Gas Door Button - Millenia 2000
Old 06-06-2010, 09:38 AM
VampLestat's Avatar
Default Trunk / Gas Door Button - Millenia 2000
I'm having an issue with my trunk button not working. I have to slowly press the button for the gas door for it to open. Unfortunately, no matter what I try to pop the trunk, it doesn't work. I use my alarm key to open it, but it's really annoying when I have the engine on. I literally have to shut the engine, pop the trunk using the remote, then restart my engine.
I've checked the fuses and everything seems fine. Has anyone had this issue? And is it an easy fix that I can do myself?
Old 06-06-2010, 01:45 PM
keninn's Avatar
my guess would be the switch. and you have to pull the panel to change it. dont forget to get the 2 push nuts to secure it, they are very hard to remove, and most of the time are not reusable
Old 06-25-2010, 01:51 AM
wilfredom's Avatar
Cool
1st instead, u do a test .. get the gas door open & then actuate the unlock open, key & remote .. if u hear a "click or clunk) a proper check to the gas door be made ..
kokorico
03-28-2012 03:23 PM
pattyd814
06-27-2009 08:35 AM
elitescouter
06-16-2009 03:31 PM
larryb711
10-22-2008 01:47 PM
delarzac
03-09-2007 01:09 AM
Quick Reply: Trunk / Gas Door Button - Millenia 2000
