'03 Miata, Replace Fuel Filter
Old 04-22-2007, 01:03 AM
gudmundson's Avatar
Default '03 Miata, Replace Fuel Filter
Regardingthefuel filter on my '03 Miata.
1) Do I need to depressurize the system before I disconnect it?
2) How to I remove the lines from the filter without damaging the clips?
Old 04-23-2007, 06:02 PM
babyhuey's Avatar
Default RE: '03 Miata, Replace Fuel Filter
Diagram below shows how to release the fuel line clips. Once line is off then transfer the little clip piece that stays on the filter back into the fuel line. You can depressurize the system by removing the fuel pump relay under the dash and allowing to run untill engine stalls but is really not necessary. Just hold a rag around the fuel line connection as you are disconnecting so it will not spray on you.
DjSlickSVG
01-27-2014 11:29 PM
Aubrey
01-07-2009 04:26 PM
Variety=Spice
10-11-2007 11:14 PM
jologs
07-05-2007 04:28 AM
HorsySce
04-19-2007 04:05 PM
Quick Reply: '03 Miata, Replace Fuel Filter
