Sponsored by:
Sponsored by:
power-connect a "female car cigarette lighter socket" directly to radio/touchscreen
Old 03-22-2017, 03:31 AM
aqurry's Avatar
Old 03-22-2017, 05:19 AM
aqurry's Avatar
Old 03-22-2017, 06:03 AM
Conrad 16.5's Avatar
I can't help you with the wiring and I don't know why you want to do this or how many amps you'll be wanting to draw from the power taps. I would suggest not drawing the power directly from these wires but use a relay that is energized by the wires in question and draw the power from another location. This way you'll not blow any fuses if you over draw the radio/touchscreen module.
Old 03-22-2017, 06:09 AM
aqurry's Avatar
because I want to connect a coyote system directly via micro usb to red/black wire ons the infotainment system. so when I start the car/infotainment system my coyote system will turn on.
Old 03-24-2017, 08:14 PM
nickndfl's Avatar
You need to tap into the fuse box in the engine compartment. Run a wire through the passenger door jam and connect a relay to one of the fuses. I hot glued the wire down because it would lift up.
Old 03-27-2017, 12:28 AM
aqurry's Avatar
can you help me how to do that pls?
dasbaer
07-26-2014 02:08 PM
afm
11-11-2008 05:33 PM
guydot
10-02-2007 05:15 PM
arillas
07-27-2006 05:47 PM
jesska
05-12-2006 01:09 AM
Quick Reply: power-connect a "female car cigarette lighter socket" directly to radio/touchscreen
